Let me start with this!
What the heck, Rennzport has been sitting on this tiny performance modification for so long and not selling it!
This is the best little performance modification you can do to your manual car...and do it without delay....
But first:
....:joy:.....
Short Throw Clutch Stop
This adjustable clutch stop allows faster and smoother shifts by removing the dead space between your clutch pedal and the floor.
The installation of this modification snaps in to place like your OEM clutch stop and is fully reversible. These clutch stops includes rubberized adjustment shims that do not rattle. For manual transmissions only. It is so easy to fit and the result is just amazing!
Just to show its relative size:
Below: OEM/Stock Clutch Stop:
Side by Side: OEM (left) and the adjustable clutch stop:
Ater the installation the car did not start and I had to to remove one of the syms for a perfect start-up. All 5 syms are recommended but you can shoose how short you want your gear throws to be. You will see this sign on your dash if the car does not fire up the first time:
The sym is the exact size of a R5 coin:
The new Clutch Stop installation completed within 5 Minutes including fooling around time. The picture on the left with the red star clearly indicates the back elbow part of the clutch that is blocked by the new stop when you switch gears. The picture on the right shows the new clutch stop perfectly and tightly in position:
How does the car drive?
The gear throws are now quicker, shorter and easier. The e87 One series owners will know how clumsy first gear feels; well no longer. I just love the smoothness in the transition of the clutch shifts.
The best is shifting in a corner...yes, I sometimes still do that...comes with age. If you forget to downshift before the corner, changing quickly in the corner is as snap as can be. That is all I can say...:thumbs:
Price: Grab this little mod from Renzport ASAP for R150.
Rennzport has two customers now running it on their manual 135s. Feedback from them will be in order. I can also already see owners queeing up before the festive season at one of Rennzports new agents (The Dent Doctor Boksburgs) premises to have this install while they wait...:joy::joy:
But first:
