Howsit all.
So another update.
this all happened over a week ago.
As you all know, in my last big update on the Turbos, i had the unfortunate experience of my wheel coming off on the road, and broke my fender.
So the search was on for a good fender, first prize was always to be a 2nd hand Silver Fender from a scrap yard. after plenty calls and only other colour, or new aftermarket fenders available, I lucked out on a Saturday morning when i saw a set of Silver fenders available in JHB CBD. i immediately called the seller and said i needed the left item, and he said it was R1500 collection at Jeppestown, no ways i was driving there, so i told him ill make it worth his while and offered R2000 for him to deliver to me in Fourways, naturally he agreed.
The fender arrived and it was in great condition, apart from some scratches and what looked like glue residue on the front.
I set about stripping the Side Skirt and Fender off.
Once installed, i needed to make sure the fender was aligned nicely to the other panels, so I took great time and care to make sure that's the case before tightening it all up, especially the bolts behind the Side Skirt and door.
Installed and looking new again.
here is a Video that was taken (informal) after the install that showed the panel Gaps etc.
Fender installed
Next was a new Rubber windshield weather seal as mine was heavily perished and cracking, so yet another call to
@deago.parts@abmbmw for a new Weather seal.
I cleaned off the old one and did some polishing of the paint that's always hidden, and cleaned the recess where the seal fits.
here is a quick (informal) video to show the new seal in place.
Weather Seal
next item to be installed is the E9x M3 Cable Cradle that attaches to my M3 Cowl setup, I've been looking for this since fitting the Cowl, and happy to say it really neatens up the Bay, i will still finalize it, as i left the sheathing on, so its a bit snug, and there is still a cable running across the motor, and also the Brake Booster line needs to be modified so i can hide it around the Back of the motor and under the Intake Manifold for that very clean look.
Last item to be installed which I don't have a photo of, was the Headlight switch, for a very long time, my headlights have been stuck in the ON position due to the head light switch mechanism breaking, so a new one was sourced via BMW and after being on back Order from Germany, it was delivered and quickly installed.
I also coded my fog lights to switch on with DRL so I don't have to activate them manually. i quite like the simplicity of it.
Next will need a Rim refurb, as well as try source a Bonnet Sound Deadening sheet, which ill order from Deago a bit later on.
Next big mod will be a Full Methanol install next month more than likely. will see how things go.
Currently i am busy logging and getting my Custom tune dialed in, as for now its very mild and I'm happy with it being mild for now. as I still have stock Fuel Pump and TMAP sensor.
As an update on the Turbo Install
@osiris and i did last month.
They have been running flawlessly, i check for leaks on all critical parts frequently, and have not seen any to date, and am very happy with the outcome of that point in particular.
car is driving smoothly, and has absolutely no issues, noises, leaks, errors, or anything of the kind that would constitute a possible problem.
The car in its current state is Flawless.
Thanks for reading guys,.
