Nice work and great to see still at it on the n54 platform
Absolutely,Clever stuff, thanks for sharing.
Also good to know the Z4 is such a pleasure, I cannot tell myself a E89 is completely off the cards given my Z history![]()
Haha yea the hands got dirtier as we continued.Very nice, a happy result.
PS' those clean hands are a sign of a clean engine, am I right![]()
Hi Bud,Absolutely,
Im not going to lie, its common knowledge that the Z4 35i/is is the holy grail, its the perfectly rounded N54 vehicle.
The subtle inclusions in the software on the Z4 as opposed to any other really give it the edge, especially in Daily Driving.
let alone the performance aspect.
Hey man.Hi Bud,
I have the PPK1 OEM BMW software on my E92 335i. BMW SA does not have an option to upgarde to 35is software. Where did you get the upgrade? I would need upgraded cooling and intercooler for this option?
Nice, It was good to see that none of them were leaking as its been bothering you for a while that you might have had a leaky injector. At least we gave the tips a good proper clean as well.Howdy guys.
So just a quickie update.
After purchasing the above seals and Decoupler elements, I arranged with @osiris and I met back at his place this evening after work as the banter and vibe is always good when working on the car.
Prepared the car
Then got out the coils, Fuel Lines and Injector brackets
Quick inspection of the bores and that all is clean and no issues
Went ahead and removed the injectors with the Precision Raceworks Injector removal tool. And proceeded to fit the injectors opposite and outside outside engine for a leakage test.
Happy to report after a couple tests and swings, none of the injectors leak which was a great sign.
@osiris even went as far to fit his old leaking Injector to Cyl.1 to make sure we doing it right and sire enough his old Injector leaked immediately.
So I'm a very happy guy.
Didn't get any pics of the seal fitment and reinstall. But it went flawlessly.
The car is still currently unassembled in the garage, but all injectors are in. Didn't want to finish and start car so late. So will finish in the morning and prime and start the car.
Hi,Hey man.
The PPK setup is a good kit. But yours is for IJE0S ROM version I believe.
The software upgrades I've done are not dealer options, and they will never update software like this onto a different car.
I did the change myself. And configured the software accordingly. Takes a bit of time and finesse, but it is possible.
I may be wrong, but the PPK should have the upgraded Cooling setup with an additional Radiator in the passenger side fender well, as well as an upgraded Fan with beefier cooling module, but at the same time. This may have been specific to the 335is from the USA. Can you confirm?
I'm running stock cooling with my software setup and I've had no issues man.
OK cool, ya, pity, you can buy the Hardware kit via ECS Tuning, but it is expensive.Hi,
The PPK1 kit on the E92 335i does not require hardware upgrades but the PPK2 kit does for the same power increase. The PPK2 kit is not available for the E92 335i in South Africa- the 335is kit in the US requires the hardware upgrade but again not available in SA
Howsit man, I have stock Downpipes, and just had the cats knocked out, both @osiris run our Stock downpipes this way, no issues, and same benefits as aftermarket DP's.Howzit, what downpipes do you have fitted? Want to fit the TMSS pipes but live in Cape Town. Need someone to take in their E92 335i, to use as a template, but so far no takers??
yup, I ran aftermarket downpipes for ages. I did back to back dynos with the gutted downpipes vs aftermarket downpipes and there was no difference in power just cooked engine mounts and irritations when trying to remove O2 sensors etc.Howsit man, I have stock Downpipes, and just had the cats knocked out, both @osiris run our Stock downpipes this way, no issues, and same benefits as aftermarket DP's.
using the 3inch aftermarket downpipes are nice, but they sit very close to the Engine mount, and end up cooking them over time. stock gutted downpipes are more than sufficient unless you aiming to extract every last bit of horsepower, which i doubt.
Just go to a local exhaust shop, and have them remove yours, knock out the insides and refit.
