BMW 135i 60 ROLL Build (THE MONSTER)
K0dAx
Damn. Definitely sad news. Hopefully you will be back on track soon
Sent from my Pixel 4a using Tapatalk
  • Like
Reactions: Dax
Dax
Sorry to hear Dax not a nice experience to go through. I hope this can be fixed and resolved soon so you can get the car on the road again.
Hi Twinz
100%, this car has so much potential if it is done right.
Gordvisr
was the new oil pump "primed" this is essential, if not done , this could also happen, turbo's will also have damage, best way of being sure , after a build like this , almost the best way to check it is to have the oil feed to turbo disconnected, plugs and coils disconnected and crank the engine untill oil appears out the oil feed line, after my build ( kadett engine ) it took a couple of minutes before oil pumped out the oil feed to turbo, priming the oil pump while assembling also took a while, after assembling the crank and mains, the block was turned upside down , i poured oil into the oil pick up and turned crank by hand untill oil was visible at top side of oil ports on top of block, some forgets this step after a new oil pump change and can end badly.
Dax
it was cranked several times, I had an external gauge connected and pressure was good before starting (Once we had pressure we did another "Long Crank")
if damage was done on startup other bearings would have taken a hit as well, if a main bearings on both sides of the big end are perfect then it is not due to oil pump.
Gordvisr
still a sad journey, you have spent so much money , time and all into it. for me its nerve wrecking to know someone else going to work on one of my cars.
gavsadler
Sorry to read about the bad news on the motor. That is heart breaking.
It’s been said by many others elsewhere in this thread. Chin up and stay focussed on the end goal. It gets harder and harder but hopefully next time round it will be 100%
  • Like
Reactions: Dax
osiris
I hear so many horror stories like this with mechanics in SA. The worst part about it is they never take responsibility for when things go wrong even if its 5km after first start up. It's always magically the clients fault.
The incompetence in this country is mesmerizing to say the least. Not even the dealerships in this country are up to the task.
Dax
My brother, you just hit the nail on the head.
//M SPORT
Was really enjoying this thread and thoroughly disappointed by what has happened to that red beast.
Wish you all the luck in sorting this out mate!
  • Like
Reactions: Dax
Dax
Hi,
Small update,
Most of the new parts are ordered, My dilemma is going to be to put it together, what do you guys think?
I took the crank to two engineering shops and both gave the same results:
Big ends 1 - 5 all to factory spec, all the same size
Number 6, well well well, this mother is between 2 and 4 Hundreds bigger depending where you measure and this was after bearing was removed and doing a polish to see if it can be used/saved
I am going to send for crack testing and if all is good I will get it polished and sell, it actually looks very good.
So this makes it more clear that the builder did not check what should have been checked. can a crank grow?
This time around we will use the new ACL Race bearings
What is that saying?
THIRD TIME LUCKY :) :) :)
I freaking hope so
Danny2
must stop watering the crank and it wont grow ;)
Just kidding.. hope it all works out for you this time and that its a happy owner when its done.
Keep up the work (y)
  • Like
Reactions: Dax
Dax
Hi,
So below are the sizes of crank journals measured by an engineering company appointed by the BMW dealer in CPT
I believe the following:
BMW SA should replace crank, it is clear that big end number 6 is out of spec (Too Big)
BMW SA should then claim against manufacturer of the crank.
The rest of the repairs and parts is on the Builder (Gaskets, Bolts, Seals, Rods and labor) it was most probably and combination of the incorrect torque and oversized journal that caused the failure
This is the first thing any engine builder should do, measure all journals and check clearances "Dry Assembly"
Please give me your thoughts and what you would do in this situation with BMW and engine builder
This is so F@#$*! Up
Hi,
As much as I think you're probably right - the odds of getting your desired outcome are slim to none, sadly. These guys all know that consumer rights in SA are worth the price of 2nd hand toilet paper, so they'll never reimburse or cover any of your costs - even if they're fully to blame.
  • Like
Reactions: Dax
osiris
Unfortunately this is the truth. I have been down similar roads with BMW several times now. They never come to the party even when they stuff up. It’s not just BMW its any dealership….the problem is South Africa is a 3rd world country, we as consumers have pretty much no rights and trying to fight them ends up being such a hassle that they win due to most people not having the time or energy to go through the ombudsman and all that crap.
  • Like
Reactions: Dax
I've been the ombudsman route - it's a massive time waster, and at the end of the day, nothing comes of it (their rulings are not enforceable in any meaningful sense). If your loss here is massive (i.e. R100k+) it might be worth actually getting a lawyer and taking things on that way, but the ombud is truly a complete waste of time.
  • Like
Reactions: Dax
osiris
I’m not sure if you’re agreeing with me or just repeating what I said about the Ombudsman? but this is Pretty much what I stated in my comment….:) It’s all a waste of time.
  • Like
Reactions: Dax
Dax
Lets see what BMW say about the crank, Engine Builder, well only one way to fix that is to name and shame and allow others to be aware of the idiots claiming to be engine builders.
I am paying proper school fees based on someone bullshitting me on how they work and it is obvious that they don't do what they say.
If BMW replace the crank it will help greatly, massive chunk of money, the fact is they supplied a faulty (Out of Spec part) if we had measured before we took the crank they would have replaced so in my opinion they should do just that. The error made by engine builder did not make the number 6 big end journal bigger.
I will update once I get an answer from the dealer.
Thanks
ja, agreement, the motor industry ombud is a proper paper tiger.
  • Like
Reactions: Dax
