Car went in to the guys perfectly fine for oil leak, which was oil cooler gasket, tappet cover gasket, front brakes and oil service, nothing wrong and no error codes when it went in. now its throwing up 931d error code and my speedometer isnt working at allzippy320 said:Yup It can , especially if its caked in oil , mixed with road dirt , sand , dust etc . Maybe try and clean it up properly and check the brushes? Brushes could also be worn out and are cheap to replace.
Whats it doing?
Ratslaaf@OBDWorx said:Speedo not working is related to a D.SC. Issue. Either the unit itself or speed sensors.
Rev counter and fuel gauge also not working would point to a problem on the PT can bus. Seems like someone messed where they shouldn't hey.
So all has gone up to shit again, any advice on what to do? I was driving on the highway and all of a sudden the car went into sport mode it now idles rough, lacks power and shudders under acceleration Fml [CRYING FACE]Ratslaaf@OBDWorx said:Excellent news bud.
So just a word of advice for you and others: do yourself a favor and check the drain holes and leaf catchers in the engine bay. These tend to get blocked and cause havoc with the wiring loom that goes between the ebox and the passenger side firewall as the engine bay is cleaned with a pressure washer. It can get so bad that the ebox gets flooded and the result is an ecu replacement - I know as I get 3 of these a week now after the rains.
As you can imagine this is a very, very costly repair and something that can be avoided with minimal effort.
Would it have a delayed effect? I drove the car for about 100kms since I got it back and then all of a sudden as im 50kms outside of pe on my way back to ct this happensRatslaaf@OBDWorx said:Yup, sounds like you got water where it aint supposed to go. Either that, or the guys pinched a cable somewhere.
Open the bonnet, remove the microfilters and cowel. When removed, youll find the clips to open the ebox. Check nicely in that area for moisture.
Also, check the loom that goes over the engine to the drivers side where the DSC sits. It really sounds like the data bus has a problem on it.
If all else fails, you welcome to get the car to me to have a look
I also had the car in m6 when it jumped into sport mode and then the kak hit the fanRatslaaf@OBDWorx said:Yup, sounds like you got water where it aint supposed to go. Either that, or the guys pinched a cable somewhere.
Eish, this is going to be a pain in the gat, well we prob guna get a rental back to ct, leaving the car with my dad, the people that worked on my car must come collect and sort his shit outRatslaaf@OBDWorx said:Yeah bud, it takes a while for water to seep through to where it shouldnt. Im not saying for sure it is, but the symptoms are there.
I can guarantee you though that the issue is related to the drive train bus being damaged and could be a right pain in the punani to find
Could a coil that gave in be the cause of this problem?Ratslaaf@OBDWorx said:Yeah bud, it takes a while for water to seep through to where it shouldnt. Im not saying for sure it is, but the symptoms are there.
