i'm trying to DIY replace my serpentine fan belt and looking for someone with a Water Pump Pulley Counterhold tool as shown below that I can borrow for a day.
Maybe a steel rod/bar 'wedged' between two of the waterpump pulley's bolts to lock it up & loosen nut?? Only an idea for another solution, be carefull for slipping though! :fencelook:
Have you tried loosening the viscous clutch by just locking the engine? (car in gear and both drive wheels on the ground) normally the bolt is not that tight, or at least it doesn't need to be.
