No news is good news!
Now that the forum is (semi) working again, I am happy to post a small update:
Currently on 115 000km
New oil & oil filter
MAF Clean
New air filter
New Diesel filter
Brake fluid flush
Wheel balancing, rotation and alignment (done just before lockdown)
For anyone interested, I followed the guide below for the brake fluid flush:
I don’t have a turkey baster, so used a pump to drain the fluid out the reservoir. It’s a pretty easy DIY.
Imcomex sent me the wrong diesel filter and I only realized this after removing the old filter. For time being the old filter is back in the car until I can get it swapped out.
Changing the diesel filter can be quite a messy affair with diesel dripping and messing everywhere. I used quite a simple trick to minimize spillage that worked like a charm:
1. Once the plastic body panels are removed, loosen the bracket holding the diesel filter in place slightly
2. Loosen the small pipe clamp on the filter side closest to the front of the car, and slowly start removing the pipe. Take the plastic cap fitted over the nipple from your new filter and pop it on the old filter as soon as the pipe is take off (this will stop diesel draining from the filter).
3. Loosen the bracket completely and let the diesel hang in a vertical manner – the nipple with the plastic cap facing down.
4. Loosen the heat exchanger side of the filter and while still holding the filter vertically take it out – all the diesel will remain in the filter. No spillage!
I am sure you can even take it a step further and drain the diesel in the old filter into the new filter to prime it before installing, not too sure about that tho.
