Kimeran
E30 Freak said:Shu where do I start
1) Evo 2 will not have ali doors, fenders & bonnet, Evo 1 will
2) An iS does not have head rests
3) Above engine no there another no. which will start with 27K....
4) The head itself is the same as the 325i so should be stamped 2.5/2.7, if it only says 2.7, it most probably an eta head
5) The airflow was definitely changed, but not even to a 535i replacement which is more similar
6) check under the panel on drivers side to see if it still has the original ECU, should also have an Alpina sticker on it
7) all panels from the tech 2 kit should be plastic & you can find part numbers in rear wheel well for the side pods & at the bottom of the spoiler
8) OAF is Evo 1, OEJ is Evo 2
9) My OAF vin Evo 1 said 325/2S
10) The OAF/OEJ vin numbers not ltd to iS models, but starts at a certain number (it is somewhere on e30clubsa)
I am no expert but that what I can recall from my car & prev searches. Hope it helps
What he said :flyfun:
