Updated: High Pressure Fuel Pump (Failures): 335/135 (Updated pics)
Twinz
Forum - Support
Was cleaning the car and took two pics of the location of the HPFP installed:
As you can see, access to the pump is pretty easy:thumbsup:
T
tibra1
George Smooth
@Tibra1 Yah we should cause a big stink with it. It hardly affects South African car and cannot say the negative press does much for our vehicles resale values.
Twinz
Forum - Support
I agree, with George...speaking to our local dealers they dont have many HPFP replacements...there are some...but not like in the US and Europe.
My only concern is that the pump failure can and has caused major inconvenience and some cases loss of finance to the driver. What if the pump fails when one is on holiday or a remote location; considering issues of crime? Anyway it seems the new pump on my car is holding out well even under high boost so perhaps it was just the bad race fuel or something.
@tibra 1...Ps. i have signed the petition...thought twice if i should give my real name but felt the matter was serious enough to make a statement:thumbsup:.
Bossman
Just a question about the HPFP on the 335i, is the pressure the same as on the 530d cp1 pump or much lower, i have a 530d with 247000k with no hassles on the pump, what is the pressure on the 335i pump?
Is the failures then mainly due to the feul quality, as opposed to the diesel hp pumps that get a lot of lubrication from the feul itself?
I am getting a 335i soon as well, now i am getting a bit worried about what i read of the problems on the HPFP.
Twinz
Forum - Support
No idea on the pump pressure.
But i dont think you have to worry about the HPFP if you have the new pump installed. If you have the old one; there is currently a recall at our dealerships to replace the old pumps...so you good to go. I have not had any issues since replacing mine and I do run very high boost compared to most, probably only out flanked by George.
Twinz
Forum - Support
Ag damn. Do you know what the number was? Might have been recycled dealer stock. I am really trying to be positive on the x35...:)
P1000
Bossman, the diesel pump and the petrol pump is very different. The diesel runs at ~1800bar, and the petrol 200bar. I don't know why the one with the lower pressure gets more failures, maybe because of the lubricating properties of the different fuels? Maybe the design is completely different and not so good in the petrol's case?
Scouse
Dunno mate but they said it was the new latest pump :thumbsup:
dlk001
Mine was also replaced with latest one Part 13 51 7 616 446. But i am now getting "Engine fault: Reduced Power" problem more often than before. In last 2 months the car will be going back to the dealer for the 4th time. They say they need to spend more time to diagnose the problem.
Diablo Jnr
Pity the fool who buy's one out of motorplan...I just find it strange that BMW have not been able to solve the problem :nonono:
Philip Foglar
Yep! The moment a proper long term solution is found for this I would actually be keen to consider buying one. Is the F30 I6 twin turbo going to be a totally new engine or basically the current 335i engine?
kabal
as far as I know it is the identical N55
nomercy
My f#cking car went in to replace a perfectly fine HPFP on a mandatory recall about 2-3 months ago, and they did the injectors. Now I have had 2 limp$odes with 29F2 code meaning the fuel pump is gone, it makes me crazy!
Really thinlk ill be selling the car and picking up a second hand 09 M3 or c63!!!
Anyone know if they also have problems!!!
It really sucks, in the middel of a dice going to 4th and your car limps!!!!
