The unlikely donor
Sankekur
Divio said:
These thread's are the best kinda threads!
:bravo:
naren512 said:
:praise::praise::bravo::bravo:
Very nicely done!! thank you for deciding to save her.
Thank you for the kind words sirs.
I reassembled the struts
uc
uc
uc
In the end my special tool did not work as it should have, or at least as I though it would. I though of a couple of other plans but ended up resorting to brute force, this type of brute force:
uc
Also notice the slight gap between the spring pad and the spring:
uc
uc
Ideally I would have needed B8's instead of B6's on these springs.
Fitted the struts and the new brake hoses.
uc
uc
Brakes fitted and bled.
uc
Car back on the ground again, and in need of a clean :mmm:
uc
Thank you for watching.
Sankekur
Removed the rear wheels to start with the rear suspension:
uc
uc
Getting the band back together, four throwing stars to go on when the work is done:
uc
uc
uc
Cleaned the mounting surfaces:
uc
uc
Gave the wheel arches a quick clean:
uc
uc
Stripped out the rear seat to be able to remove the rear struts:
uc
uc
uc
And removed the rear struts:
uc
That's all for now, thanks for watching.
Sankekur
Sorry updates have been a bit on the slow side as I had a couple of other things to sort out and finish up, but things should pick up pace again. Here is some track day action from 2017 to tide you over for now.
[video=youtube]
Thanks for watching.
VinceM
Wish I could work on my cars like this.
I must actually spend time at Gizmo’s workshop as I took my car there,
Just to learn.
Sankekur
With the diff out and it being pretty nasty from oil leaking though this would be the perfect time to change all the seals. "While it is out" "While I am busy" "While its open"
So the starting point a pretty nasty diff. (Its a 3.15 LS for those interested)
uc
https://drive.google.com/uc?id=1ufnmNgVs9vVswkExXqcYhUYg-6DZElO_
Gave it a clean
uc
https://drive.google.com/uc?id=1SbxMVuWKgNDV7cylyl4aR4Yfvx_1DNDq
uc
https://drive.google.com/uc?id=1jNgwymaOcewRMj7FVqAHT--VTA0zXuie
The parts for the diff. The shaft seals and o-rings for the output flanges, shaft seal for the input flange, new spring clips to hold the output flanges in, seal for the input flange CV, o-ring for the speed sensor, gasket for the back cover and crush washers for the drain and fill plugs.
uc
https://drive.google.com/uc?id=1tVeLOvQtrbcKzPyIpMqA1N5tLhAyTxra
Removed the rear mount so its easier to clean the back cover.
uc
https://drive.google.com/uc?id=1ZpqcCJ5HYVReWU9Ye0CtMWxvoE9huSdd
Drain the oil
uc
https://drive.google.com/uc?id=1ecPyC8CUcfQzlwxfJdD-Ik6qKnnWquIP
uc
https://drive.google.com/uc?id=1R1goXhCnEQ18jGsLmc4L57KiQyCy8pJ0
Pulled out the output flanges
uc
https://drive.google.com/uc?id=1yRTAsGx2yma8muTsgNiwSTn0ZlkBiV3H
uc
https://drive.google.com/uc?id=1IAXGnMAYDsffpVYNimL5ZH9PuJulGVcJ
uc
https://drive.google.com/uc?id=1aSbTzLVTI7_Whhnxcd-DLvES8kBU8J-J
Cleaned the removed parts
uc
https://drive.google.com/uc?id=1dWAAbUxbry2gu4e6r--wz9pfc0kyX892
uc
https://drive.google.com/uc?id=13IsYexcvCQWrz0lYcYv7DxsIrhWkrnnh
The moved the side plate that holds the shaft seal and acts as the outer for the output race.
uc
https://drive.google.com/uc?id=1vgAMH0bM_hf90zKHw70G8AA3ifPNiXHz
uc
https://drive.google.com/uc?id=1aJZk2vxBRYHb3aG4-n5-Byn5wcgwLsQ6
Bearing surface
uc
https://drive.google.com/uc?id=1pAI3nwkKc2O8Fy94G8SaWUNV9QygETww
Cleaned and seals removed
uc
https://drive.google.com/uc?id=1HDVD9x33W7cqt8huOIk9rvaf-GFr-_nG
Sankekur
Twinz said:
Thats some serious and patient workmanship:bravo:
:ty:
Moving on with the work on the diff. Pressed in the new shaft seal
uc
https://drive.google.com/uc?id=1CfydEQVn--1HSR2AuNBIZC94ruGpeYJ3
And fitted the new o-ring
uc
https://drive.google.com/uc?id=1n5W7pS8s0ThMDK2tl3ztEYbSdJZfKD8w
Did this above for both side plates and refitted them along with the output flanges also fitted new spring clips (the ones that hold the output flanges in)
uc
https://drive.google.com/uc?id=1eUEmfQT7hEsRsOPRWUVeaov-_SuOBwTg
Removed the input flange
uc
https://drive.google.com/uc?id=1rw63A8JCfIP7D_ZP2_8vRF2y-Bp9IhAD
uc
https://drive.google.com/uc?id=1-rZCdKQjDVoInCPpHR-eO8wtp-EwVRve
Removed the old shaft seal
uc
https://drive.google.com/uc?id=1B33VQ1TlQT35JDbxlMozn3cfPqJ0KRGo
Fitted a new seal
uc
https://drive.google.com/uc?id=13zzBzrBh0k_5AIxl54rG3gjZh_cCM_d0
Clean off the input flange and refitted it
uc
https://drive.google.com/uc?id=1ObCgVZz_761isCgnq5HJdsMfh7ZEhUKQ
Removed the diff back cover
uc
https://drive.google.com/uc?id=1u-HOg3KvoDuZlxskN5trc-sBkkXi5IqQ
All the parts cleaned up
uc
https://drive.google.com/uc?id=1jvcCnql4hBm83nkESOwF0Avz2WvTR76F
Back cover refitted with a new gasket
uc
https://drive.google.com/uc?id=11_q9yP4010DyP31SxT_mVjhHhDM30bN4
New o-ring for the speed sensor
uc
https://drive.google.com/uc?id=10A9HBqWbBykTabPfbMxelyvNKZCYWioj
Fitted the speed sensor and the diff rear mount.
uc
https://drive.google.com/uc?id=1GVNBQZN6fSR_YF_tq9oI36tDcQ4I77e2
Sankekur
Thank you for the kind words gents.
The final couple of steps for the diff, new crush washers for the drain and fill plugs.
uc
https://drive.google.com/uc?id=19vSMmeOuV7IJctPvsbj1wSQgl4Odt9aF
Finished off the diff by filling it with fresh oil
uc
https://drive.google.com/uc?id=1hNQDag7bFUWBdUjbUz0ojA1qEcKiEmK8
Now back to the rear suspension. Removed the rear subframe.
uc
https://drive.google.com/uc?id=112EAECRFrB4mgV9zhL4mEuG-7SeAzN0t
Gave the subframe a good clean.
uc
https://drive.google.com/uc?id=1O8cfzpREeehHCtYt-SQUUjpFFhtF7Q4s
New bushes pressed into the subframe
uc
https://drive.google.com/uc?id=15v4e7AhQNBNyiluIcfkKUD6qDxMhmRe4
uc
https://drive.google.com/uc?id=1k8h2klTNmwiKleLWg7nesGH4nYBAAX4F
uc
https://drive.google.com/uc?id=1m4iSnBleQCx3fcBSI1Px8ZIGOtPdKbdx
uc
https://drive.google.com/uc?id=1BlHPa2sA44h42YrupCXMh_rsZN3Qc8Bz
New bushes pressed into the trailing arms
uc
https://drive.google.com/uc?id=1ZxpfCyqEVuDeHvchTU3jAkK6befr2OIi
Another new part, the rear mount for the rear subframe
uc
https://drive.google.com/uc?id=1YuBTG7UuyoXDgYg_Us4YDwedDx9KEyor
Stripped the rear struts
uc
https://drive.google.com/uc?id=1I0WNpantfz9Z4lSZXMqLoujvtCbUho3I
Cleaned everything that is to be reused
uc
https://drive.google.com/uc?id=10AQFXRIlowsSBTH73v-6HQ8cN1Z7kt6h
Rear shocks assembled
uc
https://drive.google.com/uc?id=1VYx70TQ1JK7pmBkaR-F5elm6V0g_5faf
All the parts for the rear struts
uc
https://drive.google.com/uc?id=1BOrmQByYiIVTmMhd0WGGUwHXbt9kERkI
And reassembling the rear struts
uc
https://drive.google.com/uc?id=1P0nc55e0IdlpuThpkcu7FJdRSyA44rh-
uc
https://drive.google.com/uc?id=1E7qBzhzjlCx9A282NTbqylsgZM-5lsMz
uc
https://drive.google.com/uc?id=1OlegOVmWXCjpqxxEiG0tPS5pfMmLSgdS
Divio
Awesome, Impeccable work as always Sank.
Still the best 46 around....
Your 46 makes me feel like a hobo, thanks alot! :rofl:
