Andy1GP
Small update.
I'm trying to focus on the M5 at this point since I have everything here to get her up and running. Finally
Friends and duties have hindered me somewhat but such is life.
Yesterday I cleaned the block bolt holes with a compressor and vacuum cleaner. And also had to address that bloody bolt that fell down the chain guides into the sump. Struggling to fish it out with the magnetic light I removed the oil level sensor to fish from below. Still no luck. So I was kind of lost at this point.
Long story short I managed to fish out from the top after some manipulation!! Thank goodness!
Then continued to clean the pistons and sleeves again. And finally scraping the surface of the block to accept the head gasket.
Even after several carb cleaner and prepsol applications the scraper still removes a great deal of crud as can be seen by the first scrape.
Im going to strip the head and cam carrier today whilst marking the caps and shims. Install the head gasket and position the head.
I read the instructions state the head bolts need to be heated to 80 deg C and then angle torqued before and after. Giving 15min inbetween. Will investigate further first.
I am all smiles as the progress has begun toward completion and no longer stripping
