technical Strange electrical issue - Fixed, I think, I hope.
LYFGP
I posted this either here or on Facebook (BMWFanatics) a few years ago — I think it was on Facebook as I can’t find the thread here.
See video below (it seems to be an issue, but not common)
The first time my dash did this was about 4 years ago. It fixed itself and I never bothered checking it. Over the years it would randomly happen for a few minutes and “fix” itself.
On Saturday I drove the car probably over 100kms and parked in my garage, Sunday the car was not driven. Monday morning after starting the car, the same thing happened again, only now it seems to be permanent.
Has anyone else ever experienced this?
Any known things to lookout for before having to spend money?
Edit: Tuesday evening I disconnected the battery (I made sure to lock the boot lock and I put something in the ‘boot catch’ so I don’t have an issue getting into the boot🤣)
Wednesday morning, connected the battery and started the car, everything worked 100% and I thought I fixed it, but 10 minutes later, it started again.
Solo Man
I had a will not say, similar, problem when i had a 2006 120d a while back. When driving the speedo would suddenly fall to zero and then back up to the speed and some other problems i cannot remember now, and the problem was the alternator not charging as it should. Check the charge rate of the alternator. It should charge between 14 and 14.8 volts when idling. Keep your multimeter on the for a minute or two and check if there are any fluctuations in the charge rate. Mine would charge constantly at say 14.2 and then suddenly for a split second fall to 11 volts (or thereabouts) and then back to 14.2 volts. I replaced the alternator with a new one but i believe one can replace the rectifier/regulator (not sure what it is called) that is on the back of the alternator. And comes with a new set of brushes as well! It seems to be a common problem on the 1 series at the time. Just my 2 cents.
Tinuva
Staff & Webmaster
If thats true, its a nice feature of the car, to let you know, there is a charging problem, as opposed to getting stuck with a flat battery :ROFLMAO:
LYFGP
From the research I’ve been doing, some people suggest that it’s a charging issue, others suggest alternative fixes etc.
Just to note, this is on my ‘10 E90 320d
Alternator was replaced last year, although with a second hand one, so let me check the warranty on that item and maybe also just have a test done still.
AshG108
Hey dude,
Your steering column has that clock spring thingy, have you checked if it will cause these symptoms? It normally disrupts electric connections between the steering and car.
LYFGP
Hey dude,
Thank you sir.
Two workshops I went to are convinced it’s the FRM and don’t want to so a diagnostic scan so as to save me a few hundreds (which I think is fair)
Solo Man
LYFGP, first let me find it and then we can discuss a price. Will keep you posted as it is at my son's house but i know exactly where i put it so just have to get to my son's house.
Solo Man
If it is the FRM there is a guy in Springs or Benoni that fixes them for about R1500. Guy's name is Gert from OBDWorx. Can provide contact number if you are interested.
Solo Man
Here is the clock spring from one of my previous cars. E87 120d. Or E90, not sure. They are interchangeable. I bought the complete thing from a guy and only used the cruise control stalk section as i programmed the car for cruise control. I will take R550 plus courier.
LYFGP
I’ll get back to you.
LYFGP
Update: Battery test and load test done this weekend and all passed.
The new dash ‘feature’ seemed to have sort of fixed itself. As it now only happens randomly again.
I’ve got a booking with a workshop for this Wednesday only.
A friend has however done a diagnostic scan for me on Friday, and the below were the errors that came back.
LYFGP
Update to follow soon. Need a day or two to monitor the funky dash.
LYFGP
So, a few weeks ago, I went to the carwash (I was skeptical as I thought water is getting in somewhere and casing damage), but the car was filthy. Previously I checked the computer box, fuse boxes etc for any water damage, but there was none.
Before leaving the carwash on that day, the boot suddenly didn’t want to open and I thought maybe something got caught in the latch as I had quite a full boot. I managed to eventually open the boot somehow. I noticed the reverse lights aren’t working as well as the inner rear drl’s and rear Foglights.
I did some research and found quite a few posts where some guys had similar issues (mostly overseas). One post, the guy inspected the wiring loom coming out of the car and into the boot and later found a broken ground cable. I cut open the “trunking” and lo and behold, one ground cable was broke (hanging on by a thread). Fixed that and all was well. I thought that would be the end of my random Christmas tree popping up.
That was not the case, a few hours later, the dash lit up like a Christmas tree again randomly as initially described…
LYFGP
No, I did not have the car scanned and I did not take it to a professional to have checked as mechanics/people were quoting in the thousands just to diagnose first.
I was cleaning the engine a few days later and when I put the engine cover back on, I saw there’s a cable that was being pinched by the engine cover (no wonder I couldn’t get it to clip in properly). I insulated the cable and moved it out of the way. It’s been behaving ever since . I really hope I’m not jinxing it.
When I did some research, I found that cable goes to the glow plug module.
