technical Strange electrical issue
LYFGP
I posted this either here or on Facebook (BMWFanatics) a few years ago — I think it was on Facebook as I can’t find the thread here.
See video below (it seems to be an issue, but not common)
The first time my dash did this was about 4 years ago. It fixed itself and I never bothered checking it. Over the years it would randomly happen for a few minutes and “fix” itself.
On Saturday I drove the car probably over 100kms and parked in my garage, Sunday the car was not driven. Monday morning after starting the car, the same thing happened again, only now it seems to be permanent.
Has anyone else ever experienced this?
Any known things to lookout for before having to spend money?
I had a will not say, similar, problem when i had a 2006 120d a while back. When driving the speedo would suddenly fall to zero and then back up to the speed and some other problems i cannot remember now, and the problem was the alternator not charging as it should. Check the charge rate of the alternator. It should charge between 14 and 14.8 volts when idling. Keep your multimeter on the for a minute or two and check if there are any fluctuations in the charge rate. Mine would charge constantly at say 14.2 and then suddenly for a split second fall to 11 volts (or thereabouts) and then back to 14.2 volts. I replaced the alternator with a new one but i believe one can replace the rectifier/regulator (not sure what it is called) that is on the back of the alternator. And comes with a new set of brushes as well! It seems to be a common problem on the 1 series at the time. Just my 2 cents.
Tinuva
Staff & Webmaster
If thats true, its a nice feature of the car, to let you know, there is a charging problem, as opposed to getting stuck with a flat battery :ROFLMAO:
LYFGP
From the research I’ve been doing, some people suggest that it’s a charging issue, others suggest alternative fixes etc.
Just to note, this is on my ‘10 E90 320d
Alternator was replaced last year, although with a second hand one, so let me check the warranty on that item and maybe also just have a test done still.
Hey dude,
Your steering column has that clock spring thingy, have you checked if it will cause these symptoms? It normally disrupts electric connections between the steering and car.
