Stig46's E36 M3 " Project track car."
Peejay
Events Organiser
Lol. Finished product will look hot. Any new progress? What's the plans on the power plant for this beastie
zulu
Hz, what are you planning to do with the sunroof panel? Doing a similar build ......I'm planning to re-skin the entire roof. Would you be interested in fibreglass doors? Cheers
Stig46t
not sure as yet.
will probably just weld in plate and also wrap with carbon fibre look.
yes i am interested in fibre glass doors. but must have a frame to fit lexn windows.
zulu
Hz, doors will have a frame for the polycarb to be bonded to. If you are patient I will fabricate you a fibreglass or carbon fibre panel for your sunroof.
Do not weld the old panel in ....the roof will warp and will require buckets of body filler to rectify. Rather make up some brackets which can be bolted/riveted to the return lip of the roof. Then use Sikaflex to seal the gap....remember to have the paraffin on hand to clean the excess Sikaflex off. Cheers
zulu
I've only just bought my coupe....1st event on Sunday, going to use it bog standard. The doors will take some time, will do the numbers once I've made my set. Later
RowenS
Nice going :thumbs:, amazing the amount of track builds popping up. Or is it that I just never looked previously :fencelook:
AndreasSA
Looks good already!
Two things:
Do Not weld in the roof, will Not work. I Took in my E30 the original roof and glued it in with Sikaflex , was perfect!
What Mods will y do on the engine? You are aware of the oil problems of the 3.0 litre m engine?
By the way....i am also thinking about building an m3e36 for trackdays....
Stig46t
AndreasSA said:
Looks good already!
Two things:
Thanks for tip on roof
Leaving the engine alone .
Only running the gotech pro X box.
And TNT exhaust and pipe and cone air filter .
If and when I start chasing power , I have a different trick up my sleeve .... which won't involve the m3 motor .
AndreasSA
Search in the net. You have to modify the oil sump...otherwise you ggonna kill the engine if you use slicks....oil pump is sucking air and y need an oil restrictor too...Check the Motorsport catalouge of Group N car please
Inactive
Inactive
Yes I was told the same about the sump (and many other things when I built my car) and after asking around (not on the net) no one i asked has done this not even the guys with high power turbo cars......one of them has been running for 6 years and his motor has never been opened - was also told its a Golf thing.
I dont know....??
Please let me know where i can get a copy of the Motorsport catalouge of Group N cars?
Anyway Stig46t......are you not done yet? :)
Stig46t
I dont know....??
lol, i wish dude.. there's this problem called cash flow....:idea:
and also people not pitching to buy things i advertise.
AndreasSA
@ Brucet:
I know for sure about this problem, it only appears on high g forces in curves with the 3 ltr M3 E36 engine, the 3,2 litre does not have that problem (oilsump and other parts different...)
I will have a look if I can get the group N catalogue...problem might be to get it in english...
Inactive
Inactive
Im not arguing as i dont know. Just saying what ive been told. Its definitely worth checking to avoid expensive repairs.
Drama
Awesome build! This is going to be a proper machine! Btw, which track/s are you planning on using?
