AndreB320i
Just replaced E46 lower control arm bushes and noticed a torn boot on the steering rack.
Question is, can I undo the 24mm nut that connects tie rods to the rack to gain access ? This nut is inside the boot. It's easier than releasing the outer ball joint (thus far it won't budge). It seems to me that the 24mm "nut" is attached to the inner tie rod, but the ball joint inside the boot should be able to rotate so the nut can be unscrewed from the rack ? Or am I totally misguided ? I don't want to apply excessive muscle attempting to unscrew something that is not meant to go. The only videos I have seen the outer ball joint has been released and the entire tie rod unscrewed from the rack, or the adjustment joint (outside the boot) is broken which I would prefer not to do, even though I will have wheel alignment done anyway.
The new boot has a grommet on the small (outer) side which is split so it can easily be pushed onto the tie rod and the boot itself has a much larger diameter allowing easy movement for access when re assembling.
I have seen kits that include grease, this (Febi) one does not. Does the grease go in the ball joint inside the boot ? If it seems dry or dirty I assume wheel bearing grease will do ?
And lastly, all videos show an adjustable wrench being used on the 24mm nut. Why not a box wrench, surely it is a better fit ? Is it perhaps length providing more leverage with the adjustable wrench ?
