racing snake
Hi all.
I am really battling with BMW on this issue.
Recently I bought a 1997 E36 323 auto (non runner) for a pretty good price.
The motor was poked so I am busy rebuilding it.
Now the problem...
In the vanos unit there is a left hand threaded bolt that secures the vanos 'piston' to the cam 'cup'
the bolt was broken off in the vanos unit when I stripped the motor so I ordered a new bolt from the dealers (a whopping R21.52) now I have realized its the incorrect bolt as its only 15mm long and the old bolt is 25mm long.
When I contacted the agents and spoke to them they told me that all the vanos bolts are exactly the same
I have searched the web with no luck, I cannot even find suppliers of left hand threaded bolts...
The bolt they supplied me is from the double vanos motor as I have stripped a double vanos unit I have lying around and compared the bolts.
I cannot find any listing at all for the longer bolt from the single vanos unit...
I need this bolt urgently so if any of you have 1 available perhaps from a damaged unit please contact me so we can try make some sort of a deal...
Below is the single vanos bolt which is the bolt I currently require
Below is the double vanos bolt that I bought from the agents
Thanx guys!:thumbs:
Now the problem...
Thanx guys!:thumbs:
