Ok so this weekend felt a bit lazy but still did some stuffs.
Was time to remove my old diff and investigate as it had a bit of a leak. The diff u removed was a 3.46 ratio
So my drift spec diff was prepared for R300 it is a 3.64 till I find a 3.91
80w90 oil was used
Powerflex diff bushings installed
Also decided to check the condition of the subframe pins and found that they were actually loose. This is what I am referring to.
Basically from the drive terrain in the rear I can see that the following issues this car had
Loose subframe pins
Missing 1 side of the swaybar
Worn rear shocks
Left hub had 2 Brocken bolts in it
Damaged side shaft
Damaged guibo
Damaged center bearing
Brocken engine mount bracket
Rear trailing arm damaged bushing exposed
Ripped bushes on 2 of the 3 diff bushes
OEM subframe, shock, diff and arm bushes had become soft
Rear ball joints badly worn
Inner bush on on the one trailing arm had come out
I can't wait to get this car on the road again with all these worn/damaged parts replaced
Just waiting on my trailing arm as I cannot continue further
Btw I am looking for this part it's from the rear sway bar
I need the mounting bracket and bushing for a 17mm swaybar
