zaleonardz
Rishaan, where are you located.
Do you know what engine you have, what year is your car ?
Rishaan said:hey broe.....
this could be only one thing..... The "Crank case vent valve), its about R500 , and takes about 20 mins to instal. smooooooth idles after that:rollsmile:
Chucky said:Check for vacuum leaks, once the rubber hose on the manifold tear/perish or i dont know what the heck happened to it car idled like 50 year old diesel truck sounding like it was going to cut out, replaced the rubber hose and viola she was purring again,
just a quick q when was the last time she went in for a service? lol that must be the most stupid question ever its like when you don't know what wrong with your computer and you just reboot it, service = reboottry that maybe she just needs some under bonnet loving.
waaibcpt said:I seem to have the same issue. I have a 2003, 318i Touring (not Ti), Auto. It has 112k kms (service due soon).
For a few months it's been idling very badly. It has power when I accelerate and when driving is fine but when idling it drops to about 500rpm and shakes and shudders. It's like there is an anti-stall type thing that kicks in and if that wasn't there the car would die. If I switch on the aircon it helps it run smoother but not perfectly.
The problem is intermittent though. It will be fine for a few days and then do this and then fine for a few days again. Sometimes if it starts playing up I switch off the car and start it again and it goes away.
A trend I think I've spotted is that it seems to happen when the fuel tank is less than 1/4 left. I had a thought that maybe the fuel supply wasn't great when the tank is low or there is a dirty spark-plug that's effected by low amount of fuel in the tank (not sure if that's even possible).
