moranor@axis said:
do you know what the RGM warranty covers on a SC install? because the kits generally cover all the parts included in the kit so any other damage is not covered...
if RGM cover engine damage then it may be worth it but i still feel not worth the extra cost... if it was 20k extra it would be worth it...
COMPONENTS COVERED
The following components are covered including removal and replacement:
1. ENGINE: (Petrol and Diesel) Block, Cyl. head, Crankshaft, Camshaft, Piston & pins, Bearings, Rings, Conrods, Rocker assembly, Hydraulic Lifters, Valves, Valve springs, Gears, Timing chain, Timing chain tensioners and guides, Oil pumps, Gasket Set.
2. GEARBOX: (Manual/Automatic) All internal components, including Torque Converter Gears, Shafts, Bearings, Synchros, Hubs, Valve unit, Servos, Valve body, Bands and Casings (All components inside casing.) (excl. Flex Plate and manual clutch components)
3. DIFFERENTIAL: All internal components. Crown Wheel, Pinion, Carrier Bearings, Pinion Bearings, Planetary gears and LSD components. (Excluding Side Shafts and Wheel Bearings)
4. TRANSAXLE: All internal components. Differential Unit, Gears, Bearings, Shafts, Synchros, Servos and Hubs.
5. 4X4 FRONT DIFFERENTIAL UNIT AND HUBS/DIFFERENTIAL
CARRIER: (Excluding Free-wheel Hubs)
6. SUPERCHARGER/TURBO
7. PROPSHAFT:: All components (excluding tube and balancing)
8. BRAKING SYSTEM: Master Cylinders, Wheel Cylinders, Callipers, ABS ECU and Servo Unit, (excluding rubber dust covers, piping and friction surfaces)
9. STEERING: Power Steering Pumps, All internal parts of Steering Box/Rack and Pinion (excluding rubber dust covers and piping)
10. FUEL SYSTEM: Fuel pump, Airflow Meter, Fuel Accumulator, Fuel Distributor and Warm-up, Regulator (excluding Fuel Injectors, Glow Plugs, Throttle Bodies, Carburettor Assemblies and failures attributable to fuel)
11. COOLING SYSTEM: Radiator, Water Pump, Thermo Switch, Thermostat, Viscous Coupling and Engine Cooling Fan assembly (Excluding pipes, hoses and heater radiators)
12. ELECTRICAL COMPONENTS: Alternators, Starter Motor and Windscreen
Wiper motor
13. ELECTRONIC IGNITION: All solid-state control and trigger units (Excluding H.T. Leads and Spark Plugs)
14. MANAGEMENT UNITS: Central Electronic Control Units
15. AIR CONDITIONER: Compressor only (excluding regassing)
16. DRIVE SHAFTS: All components including CV joints (excluding rubber dust covers)
17. SUSPENSION: Wishbones, Bushes and Ball-joints
18. CAMBELT AND CAMBELT IDLER BEARINGS/CHAIN AND IDLERS:
Breakage and stripping of teeth. (Excluding replacement in normal maintenance
schedule and as a result of improper servicing)
19. CLUTCH: Release Bearings, Master Cylinder and Slave Cylinder. (Excludes Friction Surfaces and cables)
20. WHEEL BEARINGS:All sealed Wheel Bearings only.
21. CASINGS: Engine Block, Gearbox Casing, and Differential housing. (Excluded when covered under Major Component Benefit).
22. ALARMS AND IMMOBILISERS: Control units (Excl. Remotes and Batteries) Limited to one Claim per Policy Any number of failures or repairs occurring at the same time shall be treated as one claim. In this instance the liability will not exceed the amount of the major component benefit.
raise:
Warranty is underwritten by Santam.
