Query: 335i N54 SA records
Psypher13
Hey Guys
Can anyone shed some light as to what are the 335i N54 Records for SA
With Stock Turbos
WHP - ??
WKW - ??
NM - ??
1/4 Mile - ??
800m - ??
1km - ??
With Upgraded Turbos
WHP - ??
WKW - ??
NM - ??
1/4 Mile - ??
800m - ??
1km - ??
Thanx guys
Dean ///M
Limited Profile
My customer ThamZ has ran 12.092, 16 June 2013.
With Stock Turbos
WHP -400whp
WKW - 300
NM - est 600
1/4 Mile - 12.092
800m - None
1km - None
Trans: 6MT
Car is currently on 342wkw@744Nm. Jp can you post your's.
bmsportzn135i
Thames has a 335i.
I have a 135i N54.
Ran a 12.2 at Mtuba in October last year. Rb turbos.
6MT.
wkw is the 400kw. It various from dyno to dyno. Some are over 400 some are just under.
NM is at 775NM.
All readings are wheel kw.
Psypher13
Schweet
Thanx guys
Was just curious
As i Am Running a 335i N54 Coupe 7 Speed DTC
400whp
300Wkw
640Nm
and i am only running 12.8 currently
So am trying to figure out what i am doing wrong
UpNcOmiNg!
Events Organiser
Could be a number of things.
Got any time sheets?
Possibly down to your 60ft
Over-revving through the gears could cost you a 10th or 3 if you keep taking the car to 7k rpm.
Psypher13
hey Bud
I have Launch Control
And change between 5000-5500 to keep ca in power band
Dont have 60ft times
But i think they are decent as i generally keep up with Jacques on launch
Also run the Bridgestone Semi Slicks at the back
bmsportzn135i
Psypher13 said:
Fat Tom said:
im running stock turbos N54, 12.4 and 241 1km on street tyres
Yeah But remember Tom
135 is lighter than a saloon 335i coupe
awesome times never the less
Actually bud, this has been discussed. There is only a couple of kgs difference between the two.
if i recall, the 335 is something like 70kgs heavier than the 135.
hoosain
70kgs is a lot and makes a differance for 1/4 mile time
especially if the two cars are making similar power
akash
That 70kgs seems to make a big difference. if you had to put in like for like mods on each car with identical engines and transmissions, would the 135i not be ahead because to the weight difference?
Taking driving ability out of the equation.
George Smooth
On stock turbos I ran 12.3 at Tarlton with full weight. Making around 385whp.
With the RB's again full weight I ran 11.9 and around 435whp.
On the 1km I ran 251 on the stock turbos with 420whp.
If you dont get your 60ft down to 1.7 sec or lower you going to battle to run good times so its all in the launch and not really in the power. Best I have pulled is a 1.6 60ft but on that run I peeled the tires at the top of second so it ruined a run that looked like it was heading in the mid 11's.
Psypher13
Schweet
Thanx George
I scheme i need to get my 60ft times and see from there
Also maybe get times at Tarlton
Kish2604
Administrator
Geez you can peddle a car...
what sort of tires were on? that LSD seems to be worth its weight in gold...
best 60ft i ever got was 1.9 something...
please explain what you mean by peeled the tire? whats your launch technique?
RowenS
peeled refers to smoking the tires, i.e. breaking into wheel spin :=):
