Baracus
So decided to sell the piggy chip and go back to stock again as I kept getting knock codes in the thin highveld air. However after going back to stock the car just didn't feel right, so today I went back to dyno at Snail and it seems power is down like 15kw:dunno:???
The before and after stock graphs are exactly the same until 3500 rpms, and then the new dyno line starts to drop off? The guys reckon that the loss in power at high rpms is likely spark related and is the result of getting the 30F2 Glow ignition code, which has damaged the plugs? So off I went to BM today and bought 6 plugs at R1 300 bucks :bawling:,
Now the thing is I can't change the f#@cking plugs coz BM use an odd sized 12pt spark plug on the N54 and you need a special thin walled socket for this???:banghead:
Riaan suggested The Tool shop in Randburg but they couldn't help, showed them the plug and they didn't have a socket and hadn't seen anything like it? Have found a tool on the net but it’s like $171 and I'll need to import. So I'd really appreciate it if anyone knows where I can find the right plug socket locally or maybe borrow one from somebody that works at BM?
