Solo Man said:
I had a problem with my E60 (2006) after i fitted the tow bar i removed from Stiaan's E60 (2008). Some how i got something wrong as the airbag light and warning on the idrive came on and would not go out. Tried to reset the airbag light but to no avail. Googled it and some guy posted something about the bst (battery safety terminal) i think which he disconnected and bypassed with a 2ohm resistor. I did the same and after resetting the airbag warning with my scan tool the light stays off. Apparently the battery cable (a thick cable apart from the main one) is supposed to be "blown" apart by a small charge located in the battery terminal coupling which disconnects certain circuits.
Am trying to see the solution to the seat airbag fooler but cannot see the pictures
i've also come across this. even saw a video on how he does it.
but im not 100% sure if actually launches the air-bags if in an accident.
- he didn't mention this at all.
at-least this sensor will lauch all the air bags, rather have safety first.
on my e90 323i (2006) I first had the seatbelt problem then the air bag light came on, i reset it twice already but its just not staying off!
:hammerhead::smashScreen::YesNo:
Poscent Gonga said:
Hi Kams,
Thanks for this post.
I have the same problem with my 2005 e90 320d and wanted to ask what things you need to make the circuit? Alternatively how much could it cost me if i am to buy it locally because i can see its available on ebay but havent seen any links or stealers where i can buy it from. :smashScreen: :smashScreen:
Thanks in advance!!
were you lucky enough to find a stealer?
