P1000
moranor said:if they did not fit mini cats then that is most lightly your problem... you can try swapping the sensors around but i dont think that is the problem if you dont have mini cats... most lightly the post cat sensors are running too hot because the cats are gone... if it was the pre cat sensors then i think the engine light would come on :dunno:
i would use software to fix this if you were going to do it anyway... if not i would just fit some mini cats
*likely
The rest makes no sense to me. Mini cats sounds like a very poor solution to a simple problem. The post-cat sensors will not run too hot either, because they are too far down the line from the engine and require built in heaters to get to operating temp, even if you are running way too lean.
MSM, I agree, wait for the problem to come up again, and then swap the sensor plugs before you clear it.
Yes you could get a software fix, but only if you can find someone who can do it...
