M135i
Nikhil@TheFanatics said:akajee said:Nikhil@TheFanatics said:lol you want to start a war bud? :smashScreen: what car are you using it in?
2004 E46 325i
Ok so ive used magnatec in my E36 325i from the time i got it, prior to the 3xx xxx km when i got it, it was serviced at bmw so most likely also magnatec that was used.
On my 330d i used magnatec aswell however switched to shell as thats what bmw now supplies.
In terms of the difference between magnatec and Edge, Magnatec is not a high performance oil but for your daily drive applications its decent, but its not meant for your high performance vehicles either.Where as edge is alot better for your high revving or performance applications and does alot better under higher oil temps.
Edge is also fully synthetic while magnetec is part synthetic.
As you can see by the above responses you will get info about every other oil:hammerhead:
My personal experience with magnetec has been good and so has many others, multiple people say that it causes sludge however if you stick to crap bmw service intervals i wouldn't be surprised if it did. I have had no sludge buildup to date on my personal cars aswell as cars that i service using magnatec or edge.
In terms of what to use currently, it is suggested that once you use a fully synthetic oil you should not go back to part synthetic im also uncertain on the reasoning.
The question of other brands such as LM, Shell ect? Well its all much of a muchness, stick to the right viscosity and change your oil and filter on a regular bases and you will be fine with any "big name oil" be it castrol or lm or Mobil1
:coolShake:
Well said
Change oil at regular intervals is the best option
With regards to what oil to use Ll04 or ll01 should be fine
Sent from my iPhone
