Oil Level/Pressure warning light
ChrisBrand
Staff - Legal
The yellow oil warning light above the cluster comes on when the car is switched on but in about 5 seconds it disappears. Thus it does not stay on.
Checked the Oil level and the dipstick seems filled up to the top mark. Checked the manual just to be sure and it says when the yellow light comes on while driving stop IMMEDIATELY and check the level and fill up with oil. If it shows the yellow light when switched off it means that its just low oil level.
Not sure what i must do. Checked the rest of the engine bay and ATF oil is low. Not sure if that triggers it.
I have to be in Stellenbosch tomorrow morning at 6. Can anyone please advise if its wise to drive the car?
Legacy
The yellow light means your oil level sensor is busted and needs to be replaced. Its sits right below the oil pan. The light just lets you know you need to check the oil with the dipstick. You can drive the car no worried, a new sensor is about R700 from GW.
Sent from my iPhone using a Simba Chip
"Normal oil light behavior:
Comes on red - Low oil pressure, shut off engine NOW!
Comes on yellow after shutting off car - A little low on oil. Add oil soon
Comes on yellow while driving - Significantly low on oil. Add ASAP!
Comes on yellow a few seconds after starting and then goes off after several seconds - Defective sensor. Check oil level manually until replaced."
S
SP33DYV
moranor@axis said:
least its not a real problem :rollsmile:
It's annoying though. My 325i has started doing the same thing after a service. I got the sensor from the dealers, just have to replace it.
Dr Evil
my car does the same since i got it, I'm going to have it replaced when i do an oil service.
Sent from my HTC One X using Tapatalk 2
lol when andy sapp was asked about maintenance on his e46 after drifting it for 3 years:
"nothing much... sensors all of them"
andrewbuch
I had that annoying light for like a year, had it replaced at theast service, and no more light
Sent from my HTC Wildfire S A510e using Tapatalk 2
ChrisBrand
Staff - Legal
So its safe to say i can leave it for a week till i have time? hehe
