Low N Slow said:
Hi guys
need your help please. I have a damn oil leak somewhere and am unable to find it...i have replaced the top gasket already but it seems to be leaking at the back of motor somewhere...any advice on what it could possibly be as a preventative measure...or would you suggest i strip everything and do fault finding from there...
any idea how much a full gasket set would cost? i am thinking it could even be a brittle oil pipe...
tappet cover is very common.
With the motor cold, use your hand an wipe at the back of the head where tappet cover meets the Head.
Also check the Heat shields that cover the manifolds.
because of the motors tilt, it usually runs down onto those.
i never replaced the tappet cover gasket on the 330i Motor i swopped in and she is starting to leak a lekker amount of oil now.
Depending how bad the leak is, you may not be getting allot of oil burning hence you dont see smoke...
