OBD II Scanner
Swiegie
Hello
I am looking to buy a scanner for my 2013 120d BMW.
I do not have a clue as that what scanner to buy. I am currently looking at a Carly unit, but it seems it must be imported?
Are there any good local units available? I would like to scan for codes, clear codes, reset service lights, and maybe tweak some settings.
Thank You
T
Hi there, i believe yours is F Series,
you can go the Carly route, for the option of Scanner and Licence, its not badly priced, then what ever the duties are.
The other option is a MHD wifi adaptor, but, this is not compatible with Carly i think, but i can remember if thats true or not.
Swiegie
Thank You, I will look at all options and suggestions.
My car is an E82.
My car is an E82.
Ah apologies, then a normal KDcan cable that you can buy from Gumtree is fine, and just down load protool and buy the diagnostic Licence.
If you plan to do coding, then you will need Carly or buy the master licence on Protool.
Swiegie
Good Afternoon
I have been looking around for the scanner and software.
It seems as if most people recommend Bimmercode, Protool OR Carly.
If I want to buy the scanner tool for Protool / Bimmercode, what scanner do you guys recommend. I have seen prices from R200 to R1800.
KarshS
I have the below which i used with Bimmercode. Hardly used still new looking.
You can have it for 800 if you near centurion. I had to change to a different adapter since moving to G Series. PM
RyanOpp
Hi KarshS, might be interested
Could you please pm me with some pics
Sent from my SM-G998B using Tapatalk
Swiegie
Good Morning
Thank you for the offer, but I am based in Cape Town.
After more investigation, I think I will go the Carly route.
T
