Noisy pulleys on cold start
De@nO
In the mornings when the car is cold there is a screatch coming from the pulleys on my e46. Only happens when the car is cold otherwise its fine when warm.
Pulleys or tensioner? Possible to DIY this?
andrewbuch
my car had it also only when cold, worst was cold winter nights, it went on for a while before it warmed up enough to stop..it was the belts..
De@nO
Its sounds terrible, like a screatch, only lasts about a minute though. Its worse when the weather is cold. Some days when it a warm day there is only a slight hint of it. Did you change the belts yourself? Difficult to do?
andrewbuch
Nope had them done. was a few years ago, when the car was still my moms. Dont think it would be that difficult to do..
blaze94
Yup i had that although it was an extremely short amount of time before the squeeling stopped, mostly just at the beginning of first gear on those winter mornings. Had the belts replaced during a service and no problems since then :thumbsup:
Theo D
I also had noisy pulleys on my car when cold, I changed them and the belts. Noise Gone:thumbsup:
De@nO
Thnx guys. Seems like a common prob?
Thnx for the link Jase :thumbsup:
Cranks fine, Pretty sure its either the pulleys or tensioner, or belts.
Taking car to RGM next week wednesday for RTAB's so will have them check it out too.
How do i know if i have electric fan?
thnx
andrewbuch
get them to fit lightweight pulleys while they at it :)
Visious fan connected to engine:
Electric fan, not connected to engine..
Thought you looked at my car this morning..
De@nO
Yeh lol, mine is electric then. Thnx. lol
Look at that engine bay space! can imagine seeing a big snail sitting in there!:pimp:
andrewbuch
That is gizmos garage.. And the engine bay is even cleaner now. With the electric fan, an more space to work, i stripped the air box an air meter out, an gave it a really good clean. Still not as clean as i would like. Will do it again some time with removing the window washer bottle, an a few other things.. Want the white paint under the bonnet to shine :)
yip plenty of space. Thats what happens when the engine is 2 cyl smaller :) gizmo says that it will look sweet with a nice shiny super charger sitting about the alternator :) maybe one day :)
De@nO
Just an update, this problem turned out to be the starter motor bendix, when cold would make a noise because it was dry, had it lubed up, all sorted! :thumbsup:
Nic_s
I wonder if it's the same issue I have. Mine only makes the noise when it's really cold. So it's only makes the noise in the Winter...
This is what mine sounds like. Did yours sound somewhat the same?
<object width="480" height="385"><param name="movie" value="
"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
De@nO
Na it didnt sound like that, it was a high pitched squeal, only for a few seconds when starting the car when realy cold. The noise would go away after about 2-3 seconds.
Epoc
@De@nO ... did you get it done at RGM and how much did it cost you and how long did it take?
Nic_s
Well, I think I'll WD-40 everything over the weekend for good measure. Although I won't know if it worked as it's not cold enough anymore in the mornings.
