TurboLlew
For F30 LCI 320i RealOEM shows exactly the same part numbers for all the head parts and gasket... except there is a 1mm and 0.7mm gasket option... perhaps these get used during assembly? Could also be for 'low quality fuel version' which our cars have...
Crankshaft and bearings identical
Block identical
Rods Identical
Piston has different part numbers and 320i has a note saying it can only be ordered after measuring pin location... SO this is probably the answer to it having a different CR. Could be for the 'low quality fuel version' which should have a lower CR too...
Block identical
Rods Identical
