N54 HPFP upgrade
KrS24
Ola gents
Anybody upgraded there HPFP? Thinking about going down that road but there is only one option at the moment - Vargas Link
I know the HPFP is a common upgrade for the VAG guys. Would be awesome if someone did this locally as well.
Kish2604
Administrator
Bro! dont fiddle with whats not broken, you have a long way before you start maxing the output of the HPFP and a vaible solution needs to be sought for...
i would rather forus the energy on maintaining the small items and keeping the engine in tip tip condition...
KrS24
Been logging the car with the JB and the HPFP drops to 9. So i thinks its on its way out. Going to need replacing anyway. I think BMW is selling the 1M HPFP to all N54 owners. I hope they don't have the same kak we do.
Kish2604
Administrator
i replaced my Hpfp as well, mine had an index (1) version and was replaced with an index (3)... touch wood the logs are strong!...
if you find the hpfp is lagging a bit you can bump your open fuel loop slightly to counter it, its not a solution but rather a stopgap for now, alternaively you can lower your ethanol ratios and the pump should recover a bit.
