discussion N20 coolant pump fault
georgefouche57
Good day all. Bought a 2012 BMW x1 2.0i sDrive a few months ago with the n20 engine. Recently the cooling fan started running since ignition on even if the engine is cold. Diagnostic picks up faults on the coolant pump. The pump still runs fine. Could it be the thermostat failing? Or what else could I look at. Kindly see attached print out slip from diagnostic.
Regards
George Fouche
