osiris
Pho3niX90@OBDWorx said:Congrats on the purchase. The 330 was the funnest car I have owned.
Get yourself a clutch stop, it will give you faster shifts and make the clutch also feel beter whrn eliminating the play down under.
Then a 3.38 diff ratio, give gizmo a call, makes a world of a difference. Can't say what the 3.46 will feel like.
Then get yourself some tnt branches from moranor, you wouldn't believe the imlrovement on torque. But I went ahead and did a complete custom exhaust along with the branches.
And then get yourself some koni adjustable shocks from moranor. Set at their hardest the ride was softer than stock shocks, but the car sat on gravel like you wouldn't believe.
And then lets do software![]()
Sent from my SM-G925F using Tapatalk
Also remove the CDV. Car will feel beter with shifts. You will love it.
Diff is around 2500
Clutch stop around 200, but you can easily make your own.
Tnt branches was around 3000
Full exhaust was around 6000
Konis was around 10000
Software 3000
And CDV is free when you remove it yourself.
The diff will increase you fuel consumption by .1, but you will have tons of torque down low and 0-100 will improve drastically. However you will lose top end. Unless you are driving 250 a lot it shouldn't matter.
Thanks for all the info and a huge thank you for the Magic erasers, they work like a charm its unbelievable!!
