So I ran into my first proper issue, as per previous post the PDC stopped working and i changed the fuse, issue was resolved for a couple of days but then started again intermittently , i noticed that when i put the car in reverse the pdc activates and works , however if i put it in drive thereafter the pdc button starts flashing and then stops working even if i put it in reverse again.
I was thinking probably one of the front sensors had gone but after some googling and watching a few YouTube videos i noticed that this is a common problem with the E82s as water fills in behind the wheel arch where the module sits, this made sense to me as the issue only came about after I had the car washed and stuck a pressure hose in the wheel arch.
I went about stripping the rear boot trim and low and behold the module sits in a polystyrene housing and it was quite damp inside.
I removed it, dried it out and put it in a bag of rice for a couple of days but this didn't work , the unit had mold and is most likely kaput.
I was lucky to find a used module with a different part number from an E87 that works perfectly, so i decided to wrap it in plastic and mount it above the initial housing spot, i hope this is a long term solution.
However if anyone knows where i cant get the original pdc module repaired , please let me know.
