Hi Guys.
There is no real update. However i took my car for a check up last week Friday. The car is currently with the Mechanic.
These were the points I noted to him
- Front wheel bearings
- Steering Angle Sensor
- Car smoking a little (Valve stem seals)
So he comes back to me saying that he completed a compression test and it is low and due to the mileage been over 200 000km I will need to overhaul my motor. That sounded great, infact that is what i expected. The reason i took it to him initially is because he gave me a very decent price late last year for a complete overhaul.
I know it is not a must and I could try changing valve stem seals, or tappets covers, however I have aftermarket warranty. The warranty will only cover if the motor is stripped. So redoing the motor is fine with me as they cover a fairly decent amount.
The oil is not burning heavy. On the road you won't even notice it. The oil level also takes a while to drop.
However, the quote he gave me last year, literally doubled this year. Apparently the price of pistons shot up, I feel this guy is getting greedy. So I requested that my car comes out, I will pick the car up soon.
I then called Nige Auto in Benoni. A RMI approved mechanic. I dealth with him before and I never had any issues with him. So I cannot judge. He gave me the same price, he gave me a few months back. :thumbs:
The reason I am not mentioning the Mechanic is because I cannot judge that his workmanship is bad. I feel if someone gives you a price and you agree, that is your own thing. So i cannot derail him. However, his price last year and Nige Auto's price was very very similar. Like a thousand rand difference.
So Nige did say that he is busy at the moment. I will be sending my car there probably end of the month. As he is busy up until next weekend.
I asked him to overhaul my motor, basically make it brand new. That is new gaskets, seals, rings, bearings, water pump, oil pump, pistons, sensors, valves, everything.
I will ask him if its possible to document it for me. If not i will pay visits and see the progress and take pictures where I can.
So a huge update pending...
