WaNaV8GoCart said:That Sparco is a beautiful seat :clapper:
I can only assume harnesses will be installed with the cage....
Gizmo said:WaNaV8GoCart said:That Sparco is a beautiful seat :clapper:
You are correct. My wife watches street outlaws with me and after seeing chief's crash she is 100% convinced that I need a roll cage, she is so convinced that she offered to pay 50% of the roll cage cost.
I bought some universal mounts with the seat but because of the layout I was only able to use the outer one, inner mount is custom flat bar drilled the same as the universal mount. As far as the sliders, I had those left over from seats I bought from autostyle several years back. It takes a lot of trial and error to get the seat position just right so don't be surprised if its not right the first time, as far as building one for a customer, I suggest these:splintheter said:I dont suppose you could make me a seat rail and charge me for the privilege? Have a Sparco waiting to go in track car, but last rail made for me was rubbish.
Sent from my E5823 using Tapatalk
Fuel pressure. Water temperature (outlet). Oil pressure.Fordkoppie said:2x oil pressure gauges?????
yeah the H&R springs I installed actually raised the car. Unfortunately the bilstein B6 shocks don't have height adjustment so I will have to ditch them in favour of some adjustable shocks. Herman has a set of bc racing shocks for me that will work perfectly, just waiting for him to finish removing them.Captain_Stealth said:Front needs to be lowered
