With the engine running, get access to the belt and run a bar of soap on the belt, the part which comes into contact with the pulleys. Do it for 2-3sec and let the belt cut grooves into the soap bar. This will stop any belt squeal. If you still get squeal then it could be an Idler pulley or even the alternator bearing.
