Just a question, are the injectors coded cylinder specific or does it not make a difference that 2-3 are swapped around with 4-6?
Sent from my PRA-LA1 using Tapatalk
Check the numbers stamped just below the electrical connector. ...
Below is a shitshow diagram for the  location of the 6 digit number needed when upgrading / changing / diagnosing etc...
IF YOUR CHASING A MISFIRE..... you can squeeze a cellphone down between each coil and injector and take a picture of each fuel injector so you have a reference for the location of injectors. If you don’t have MHD, bimmergeeks protool, or impa/ista (Model specific diagnostic and coding software tools) or access to someone who does, after you complete swapping injectors to see if misfire follows, YOU MUST RETURN EACH INJECTOR TO ITS ORIGINAL LOCATION. The 6 digit number I’m referring to is bmw’s way of making sure that the fuel system consistently  delivers the correct amount of fuel to each cylinder for optimum performance, especially when it’s tuned. There are several different “indexes” of bmw injectors. They look the same, but are vastly different. each index having its own specifications and capabilities. LOOK TO SEE IF YOU HAVE TWO OR MORE IDENTICALLY NUMBERED INJECTORS FIRST! IF possible, try using injectors marked with same number code. That way, when chasing a misfire or diagnosing issues, YOU KNOW FOR SURE YOU FOUND THE PROBLEM. Interchanging injectors, even when it’s done on the same engine, can yield misleading results due to each injector having very specific values, often having vastly different specifications even when swapping injectors around on the same engine. This is why people are so redundant when saying injectors / etc. must be individually computer coded when any change is made. It’s an annoyance, any bmw owner will surely agree just how annoying owning a bimmer can be, just as he shall agree it’s the price one pays to drive a beautiful engineered high performance machine..”the ultimate driving machine”, -BMW.
Here’s my best shot at explaining where, what, when, how and why.... not easy. At all... don’t bust my balls please.... I gave it a spirited effort..-
Here’s the directions to find the BMW fuel injector CODING VALUE.
  It’s a 6 digit number. printed in Two rows,
  (3 digits stacked above 3 more digits),
  laid out as,,
                             555
                             555
                If the injector was
                   In your hand,
            Maintaining the same
         Orientation as is installed,
                                               .                                                Wire   Plugin          Fuel ⬇️Line
         IIIIII.                  (======)
         Iiiiiii.          II.         IIIIIII
H      IIIIIII.____——____IIIIIII
E       IIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII
R ~>  ( 573 ) IIIIIIIIIIIIIIIIIIIIIIIIII
E ~>  ( 224 ) IIIIIIIIIIIIIIIIIIIIIIIIII
                  IIIIIIIIIIIIIIIIII
                   IIIIIIIIIIIIIIII
                   IIIIIIIIIIIIIIII
                     IIIIIIIIIII
                     IIIIIIIIIII
                     IIIIIIIIIII
                     IIIIIIIIIII
                        IIIII
                        IIIII
                        IIIII
