corp
Just an update:
Car was taken to an auto electrician trusted by CCD. Based on the information provided to them, they were told the car doesn’t start. Because the water pump kept running it drains the battery. They charged the battery and fix the water pump continually switching on by adding a relay on the line.
They drove the car around and had it idling a while. Initial issue of the motor cutting out and not starting didn’t return.
I test drove the car with one of the guys whilst they had the Launch software connected and monitoring the vehicle. Not a single fault when when it reached operating temperature.
CCD has replaced the thermostat that burnt out so the temp gauge on coolant seemed fine too on the readings.
I paid and left, drove about 50km to fetch my belly pan cover. The car did not want to start after stopping there. 2min later it started again.
I drove to the client, about 5km away, and the car stalled twice. Each time the half yellow engine light came on. I stopped the car and it started up immediately. Parked the car at my destination and let it idle. Car eventually stalled again and hen wouldn’t start. Same as last time, same codes appeared and the started later when the tow truck arrived.
