Maxtrac coilovers
Doomsdaya
bac said:
back from the dead, if you guys had to suggest a good DD coil over setup, car wont be tracked so dont need too stiff, just a good replacement for my worn out old shocks, and also would like to go quite low as well, its for an E46 m3
Thank you for resuscitating this thread :) I've been thinking about this ever since I fitted new shocks couple weeks ago....
I'm also looking for coilies but not for track purposes, just for the looooooow of it ;)
The spring/shock combo is fantastic but theres a time when speedbumps turn into mountains & I need to raise the car a little....
bac
thing is i want to go really low also, so normal lowering spring not an option. Looking at ST, v maxx, BC racing, ground control etc all seem to be within the R7k price range
I really dont see the point in riding around on crap dampers incase i need to raise the car a little?
I would rather make a spacer up to lift the car if i absolutely had to... adjusting coilovers is not a 5min job and you have to for alignment when you change height because your angles with change with the ride height...
again if you care how your car handles and rides dont buy crap dampers :rollsmile:
of the lot BC is probably the 'best' but KoniSA take off alot of these cheap coilovers to replace with proper stuff... make sure you keep your shock mounts or you will have to pay for new ones if you not happy... 7k is alot of money to spend on something you might not be happy with...
then again you cant go super low without addressing control arm angles so handling and ride goes out the window anyway...
If you look at the cheap kits they all lower more than proper kits because they dont care how it affects the car...
Doomsdaya
Lastnight a little big birdie told me of a brand called KW :fencelook: & theres JOM...
Indeed, but how long does spacers take to fit compared to adjusting height for coilies ???
KW is a proper coilover they wont go for 7k...
yellow speed is the same as BC and D2 they the same with different valving and spring rates
Theo D
Cool ! And what about JOM Coilovers ?
I've only heard bad things about V Maxx coilovers though :thinking:
:thumbs:
JOM is real kak like Vmaxx i would not fit that to my mother in laws car...
if you want to do it cheap you going to have to cut somewhere if height adjustment is important to you then you get kak dampers... if you get proper dampers for good handling and ride then you get a fixed ride height... there is no magic company out there that can deliver both at a cheap price...
Doomsdaya
But but but mr moranor..... Koni is too expensive :cry:
Unless we do a group buy & get a good discount :rollsmile:
Doomsdaya I only make a few hundred of a pair of shocks where am i going to find discount :cry:
nothing wrong with ST but H&R have a coilover range at similar prices...
I will never say my products are the only ones that work there are a few out there that also do a great job that i do not yet sell :)
but what grinds me is people who say they love and appreciate their fine German engineering then go and fit some rather laughable cheap 'Chinese' crap all in the name of getting 'coilovers' because you know 'coilovers' are awesome it does not matter how they made...
zama
I am also still deciding on coilovers or shock & spring combo for E46 M3.
I'm leaning towards Blistein PSS 10 or KW V2. But the price :fencelook: :argh:
Koni Yellows and Eibach spring seem to be the favourite combo from guys abroad.
zama that is an awesome combo :) I can get you both Eibach/Koni Sport as well as a Eibach/Bilstein B12 combo...
4PipeR
BMW Car Club Member
That bilstein looks really good ...
4PipeR said:
Can you only get the B12 ?
nope sorry Eibach sell them as a package :( if you find a buyer for the springs i can split it up for you :)
If you looking for a damper setup Koni Sport is great and you can use the dampening adjustment to fine tune your handling and ride... where the bilstein B12 are better is under very high grip levels, spring rates and down force not what you get on a street car even if you have semis...
nothing wrong with Koni sport on street/semi slick tires and the dampening adjustment is quite useful if you want perfect handling
4PipeR
BMW Car Club Member
If you looking for a damper setup Koni Sport is great and you can use the dampening adjustment to fine tune your handling and ride... where the bilstein are better is under very high grip levels and down force not what you get on a street car even if you have semis...
Sorry I should of phrased my question a bit better... Can you get any other bilstein kits like the B16 ?
How many mm drop in the front and rear with the eibach/bilstein setup ?
And what price are we talking ?
the Bilsteins i get are though my Eibach supplier so i cant get B16 :(
I assume you want for an e46 M3?
Its a -20mm Front and -10mm Rear R 12,380 (because of M3 inflation factor most kits come in under 10k)
4PipeR
BMW Car Club Member
Yes its for an E46 M3. Mmm I wonder if that drop is going to be enough for me ...
Do you maybe have pics or does someone else have a b12 kit on their e46 m3 ?
