maf/o2 sensors change
lencel jacobs
Howzit Guys my e46, 318i, 2000
is giving me a problem i need some advise can any one help me.
i have just changed the maf/o2 sensors with new ones:joy:
because i did a diagnostics test and lambda sensor came up so i changed
it with a universal bosch o2 sensor and my maf was faulty because i tryed
one from a frends car and found that my car idle was beter than ever .
erased error messages but the o2 sensor error still came up so i erased
adaptation & erased message again but still some .
then disconnected the battery for 1/2 a hour reconnected it erased Dme
no errors but the cars idle still dipps from 869 rpms to 500rpms at the robo .
i checked for leaks didnt find any witch one of these two sensor could be
the problem .....:argh:???!
thanks god bless.
Diablo Jnr
Assume you checked your resonator box when you replaced the MAF...my box had a whole in it and was causing the idle problems
P1000
The wonders of the generic lambda sensor... Just do some research and order it by the american part number at a shop like take2.co.za and it will be like R500 for the real thing.
lencel jacobs
hi guyz i spoke to a mac and he had the same problem once ,A customer came in to he's work shop wanting to change the lambda sensor but he had the universal one and mac toll him this sensor works but not 100% :thumbdo:so he said put it and the car was ok:ty: but the next day he was back the said i told you so:roflol:. He bought the right one and it was 100%:joy:
