No only the speed governor.George Smooth said:phantom said:This car is running into the rev limiter hard at 7500rpm top gear.Anyone out there qualified to remove the limiter?
Didn't the software remove it?
phantom said:No only the speed governor.George Smooth said:phantom said:This car is running into the rev limiter hard at 7500rpm top gear.Anyone out there qualified to remove the limiter?
phantom said:Software updated.Rev limiter moved up to 8800 RPM and speed limiter to 340km/h.
Waiting for track to open up. :thumbs:
phantom said:Software to follow, but one thing at a time.Sherwin@xcede said:He needs s/w as well.
Andy1GP said:
Thanks for the images Andy.The branches being made come straight out and form together where the cat is.This makes for a much better runner and if i am right will give a lot more high rev power due to less restriction.Will post a picture of branches later.
I think the torque might suffer at low rpm but then again you need the power at high rpm when you race.
I don't think he is in JHB area.quattro said:Talk to OB from Chip Logic. I'm sure he can assist you here with setting of the ecu/software to give you the rev limit and top end that you need.
