I just finished the a manual conversion on my e36 and ended up with a bad getrag 250 box that sounds like its got straight cut gears so im on the lookout for another box.
Came across a 6 speed box(GS6-17BG - TAPT) from an e87. Is this a doable swap for an M50 - looks like it will bolt up but im not so sure of what else needs to be done to make it work? Thinks its the same as the e90 6 speed(may be wrong)
Or should I just go for the ZF from a 328i? Should mention that im still using the 3.91 Diff (actually like the ratio:rollsmile
Any input appreciated...
