Thread continuation, the M3 is now with me for the non motor related issues and boy there are many...Where to start?
Lets start on a bunch of parts to be fitted.
Reason for replacement glass.
Electrical issue, notice the key is out but ignition switch still in 1st position, this drains the battery in no time.
Underneath, where most of my time will be spent presumably.
Ghetto exhaust hanger.
Will be interesting getting this bolt out.
Lots missing, pork chops, air ducts, centre splash panel, hooter.
Missing a fastening bolt.
Simple fix.
Current rear shocks.
Front shocks, note sway bar end link mounting points, the replacement shocks don't have these, will make a plan.
At some stage 3.2lt headers were swapped on, pointless as they no different to 3.0lt headers bar the bungs for oxygen sensors, which these have been cut off anyway. Our SA market M3 3.0lt doesn't have oxygen sensors.
Possibly needs new crush washers and bolt.
Missing 10mm bolt.
Oil leak, I count 3 different silicon colours on this point, Drei Bond (clear), black silicon and grey silicon, none are working. Also note the cute little earth strap, lol.
Leak around/on the reverse light switch.
Insulation has collapsed onto propshaft and exhaust.
Cable tie came off the steering boot.
Exhaust and heat shield off.
Wrong nuts.
Collapsed insulation and the propshaft coupling says 1999.
Insulation started catching fire.
Wrong bolts and flimsy washers.
