giving your 330 brakes a little more fade resistance due to more thermal inertia from the thicker discs
netercol said:e90 330i
diameter : 330mm
thickness : 24mm
height : 73.7mm
spigot : 79mm
netercol said:anyways , found the specs..
e46 m3 discs
diameter : 325mm
thickness : 28mm
height : 52.5mm
spigot : 79mm
e46 330d , 330i
diameter : 325mm
thickness : 25mm
height : 52.7mm
spigot : 79mm
seems to me m3 discs can be substituted for 330d,330i discs.. giving your 330 brakes a little more fade resistance due to more thermal inertia from the thicker discs (28mm vs. 25mm)
so anyone here know where the m3 discs might be bought at a reasonable price? (obviously not from stealers)
e46 M3 have a 345mm rotor in front
Is the wear limit not 4mm on your car? That would mean that you technically only have 1mm left on your new discs?
the difference between non m3 and m3 brakes is not only the thickness.
m3 discs are drilled, and floating
