JB4 (N54/N55) Support Thread, South Africa
outlaw335
Thats what i love about the jb.Updates can be done at your own leisure,settings can be played around with to suit your own preferences instead of running to your tuner for updates every other week.Its an awesome product.
Need to update to 6/10 asap.
ed_z
G5 board here thanks Rennzport can't wait to see what this baby can do next week. Launch control with figures of .6 bar on standstill, 2nd gear launch and flat foot shifting!
Twinz
Forum - Support
Finaly some joy for the N55 guys. Map 5 is now available and you going to love it. :thumbs:
Please update the latest firmware below:
7/1 HEX FIRMWARE
1) Improved boost targeting logic.
2) Implemented a BETA autolearning map 5. Currently suitable for pump and race gas, including E85 mixes of 20% or less. For higher E85 mixes see item #4
3) Corrected bug with air intake temperature not showing in logs.
4) This firmware is the first firmware that will support the optional E85 fueling wires, which are required for those running E85 fueling mixes of greater than 20% without methanol. You may run this firmware without the wires but do not run stronger E85 mixes until the wires are installed.
5) Revised methanol map 3 for stronger low end performance and a more seamless transition from no meth flow to full meth flow.
6) If updating from some older firmwares you may need to remove keys, lock doors, and wait 5 min, for DME to reset. If logging RPM goes wacky in log, etc, post update follow this procedure.
Dean ///M
Limited Profile
Thanks for the N55 update. Didn't see this but Terry did send me some firmware which he was testing about two weeks ago, wonder if this is it cos I sent him a lot of logs and he was happy with it.
Twinz
Forum - Support
You can ask him if its the same. I suspect it is the same it was probably in alpha stage at the time. But upload beta as soon as you can.
skiet
Hi all.... Just want to get some insight from you with regards to the jb4.
We have a dyno day this weekend at KAR and im going with jb4 in.
What octane booster do you use and how much of it?
I know best is to get shell 98 race fuel etc but i cant get a hold of it for now.
Is the NF Ultra good? how many litres should i mix it with?
:ty:
Dean ///M
Limited Profile
Mix Nf with 20L of pump. Dyno on Map5 but drive around for abot 50km's first on Map5 so that it adapts nicely.
Twinz
Forum - Support
Agree. If you get 2 runs, you want your first run to be the strongest :idea:
ed_z
G5 holds boost longer and more consistent and car reacts a lot quicker now as well. Seems like the G5 board has loads more intelligence than the G4.
Thanks Rennzport for super quick and efficient service!!! And what really impressed me is that you guys actually did a lot of homework and research on the G5 install and back up etc cos if you did not then I would still be scratching my head! LOL
Thanks guys!
Twinz
Forum - Support
And alot more boost on each of the maps. Map 5 is rediculously powerful. :thumbs:
Installing the Sld & the Cps were a challenge even for an experienced hand like mine. But it was because i was not sure which Db9, BMS was refering to. :=):
Look forward to run the nitrous now with all the additional safetys. :thumbs:
Will post the details in post # 2 on this thread tomorrow.
ed_z
Yeah agree a lot more boost on any map in fact. Will try all them maps tomorrow. Hmmmm Nos........
J
Josh-ZN
am going to run the update on my jb4 this weekend.
:rollsmile:
ed_z
BMW Car Club Gauteng Excede at KAR dyno day was awesome and my wagon took 1st Place out of all the 135i and 335i.
385Hp and 734nm with no meth as i never activated it:thumbs:
Still can get more out since i only adapted 5min before run and that G5 board needs alot more settings inputed than G4. So will keep posted on future figures when i get these setting spot on.
Savspeed took overall with Sergoi's wagon pulling a 622Hp with boost leak that creaped in.:praise:
