Hi guys
camron e36
Hi all .I have a BMW e36 316 96 model and it has a lack of power problem and it sometimes jerks ...does anyone know what the problem is .please could you help .I've tried and replaced parts and its still the same
Thanks guys
Sent from my ALCATEL ONE TOUCH 7041X using Tapatalk
camron e36
651 drop said:
hi
have u replaced the fuel filter or had the car serviced recently.
good luck
Hi
I changed the fuel filter and the only one had some black dirt in it ...so I was thinking maybe my petrol tank has got dirt in it .and it really doesn't feel like it has power ...I was even thinking of changing the engine
camron e36
danieljames said:
Yeah........i think it's coz u missing two cylinders.......
Hahaha thought the same thing ... What 6cylinder do you thing IG good for the e36
ballisticz466
I have the 325i, and I have no issues where power is concerned. From what I have heard, the 328i has better torque than the 325i. Same kw, just the torque that differs. And then you get the Vanos and non Vanos engines as well.
camron e36
I'm really thinking of doing a swop of engines ...is your 325 heavy on petrol
danieljames
M50 I think would be the easiest to swap in due to electronics but I stand under correction....I'm sure m52's are dime a dozen but I haven't attempted a swop of any sort ever so I ja
I average around 9.3 l/100km daily driven and around 7.8 up to plettenberg bay
camron e36
That's not bad ..and the 325 engine will fit into my car so I'm gonna get prices on the engine and will take it from there
ballisticz466
I have a auto, so it's not the lightest car you can have. Not sure about the manual 325i, Daniel will comment on that. Also depends on your driving style.
Lood voet soek juice!
camron e36
I'll find out everything before I go ahead ...because I was thinking of putting a turbo in my BMW but maybe a 325 engine is better
danieljames
Lol!!! Gizmo.
I think an M50 will be better for turbo as it's a cast iron block as apposed to the m52 block which had iron liners.... and u could always drop the m54(e46 330i) crank rods and pistons straight in the M50 block and end up with a 2.9 l.....because displacement
