Ga-3M said:
Rather put stock Z4M rims than CSL, my opinion good sir.:=):
I'll fit all 4 of the OEM rims once I've returned from the Cape in August, you'll see how weak the car looks with them on... hence an alternative design is required.
All I know is, the current front setup is hardcore.
Mind you, perhaps I need to have these 20's checked, I'm pretty sure the fronts can be reduced on the hub, which might solve the problem.
It's is not uncommon for guys running 245 up front on these M's, so perhaps all I need is that 5mm reduction in the center.
This will be better understood upon inspection of the car, and once again, this is based more on my preference, and not functionality, as the current setup does work, just not perfectly.
