LordPhoenix
Easiest way to bring the consumption down, is to reduce pressure of right foot against accelerator....:fencelook:
LordPhoenix said:Easiest way to bring the consumption down, is to reduce pressure of right foot against accelerator....:fencelook:
LEONCHULO2012 said:Hi There,
can anyone up there knows how to bring down the petrol consumption in a 320D E90 BMW 2006?
the car spend 9.5 in the city and 7 on freeways
regards
Javier
Dippies said:husain333 said:Dippies said:Well i use 50 ppm and is roughly as I posted in previous post
How often do you reset the Consumption meter that displys your km/l ?
Reset of meter km/l
Diesel 50 ppm or 500ppm
When last was it serviced
Diesel Filter
Load carried
Average speed also has influence on the computer to work out consumption
Where do you fill up? Cause there can be mixture of paraffin in?
all related to Consumption issues.
Lately being resetting every morning.
I have tried both 50 and 500. To empty and refill of course
Car was serviced 2 months ago
Very rarely have a load
Being keeping to speed limit. Have enough tickets
Use Shell service stations
Ok please stop resetting the counter as this is used to calculate the consumption using distance traveled and average speed. Try and only reset the interval at every tank fill up with Diesel 50 ppm. I would not try using 500 in my car though :fencelook:
this will mean that the average consumption is calculated per tank and not per trip, as this stage. If the car was serviced it is not necessarily to say they did change the diesel filter!
Try it for a month and c where you end up.
Where do you reside what area.
m0lt3n said:hey hussain. how many km's do you have on your car?
also, if you dont still have motorplan, whet did the filter and recalibration cost?
and how long did it take? i dont have a dealership in my one horse town...
my consumption is not that bad...but there is no way i will be getting 4.5 at 120kmph
Dippies said:m0lt3n said:hey hussain. how many km's do you have on your car?
Nothing is stopping you from getting the same results my car has now got 118k on and i get 6.2 in the Town and 4.5 on open road with avg speed of 130km/h speed control
Dippies said:130km
Dippies said:130km
