Hi Gents...Ive had it with my stupid e36 :smashScreen:. one thing after the next it seems.
Is it possible for the guibo to rub against the selector rod?
For those who dont know, I recently swapped in a ZF gearbox. It uses the larger diameter guibo. When I reverse, these a squeaking noise. Somewhat sounds like metal to metal contact. When going forward, there's no noise when I accelerate but as soon as i let off the throttle theres a horribly loud squeaking noise.
I got under the car last night and checked the entire propshaft for marks and signs of contact and found none. When jacked up I can turn the wheels and the prop - no noise...no rubbing. Checked the guibo and found that the selector rod is very close to the guibo. Popped the car into reverse, and it gets even closer. Theres no obvious marks on the guibo though.
So back to the question...is it possible for the guibo to rub against the selector rod when weight shifts to the front?
