Good wheel cleaner
Kyle
Clean green is an all purpose cleaner which will never be as good as a designated wheel cleaner
Drama
Meguiars hot wheels tyre cleaner works like a boss!
I spray them onto my rims, leave them for a few minutes and then spray the rims with the hose (Karchar machine) the rim cleaner is so good, simply using the high-pressure hose removes all the dirt and there's hardly a need to physically wash it afterwards.
Kyle
Wheels will always need agitation to get them 100% clean, especially around the lug nut holes/barrels.
Leaving these areas neglected will save you from having to refurb rims
PS. Meguiars hot rims is an excellent tire cleaner as well.
Drama
Hardly*
Kyle
Hardly*
Seems you have it sorted then, forgive me for my insolence
Hotclutch
You don't need dedicated wheel cleaner like Iron out or dragons breath on a regular basis. After the wheel's been decontaminated you should seal them up with wax, and you don't need expensive stuff. Then you should clean the wheel regularly like once a week at least to prevent build up. It helps to remove the wheels when cleaning, maybe not every week but once every six months i would say.
Pri
Hey guys where can i find 'Auto Finesse imperial wheel cleaner'? i am in Durban. I have the same issue with break dust i would like to give this product a try.
